* Database.php
* The Database class is meant to simplify the task of accessing
* information from the website's database.
* Written by: Jpmaster77 a.k.a. The Grandmaster of C++ (GMC)
* Last Updated: August 17, 2004
include("constants.php");
class MySQLDB
var $connection; //The MySQL database connection
var $num_active_users; //Number of active users viewing site
var $num_active_guests; //Number of active guests viewing site
var $num_members; //Number of signed-up users
/* Note: call getNumMembers() to access $num_members! */
/* Class constructor */
function MySQLDB(){
/* Make connection to database */
$this->connection = mysql_connect('localhost', 'root','parolata mi' ) or die(mysql_error());
mysql_select_db('databazata', $this->connection) or die(mysql_error());
* Only query database to find out number of members
* when getNumMembers() is called for the first time,
* until then, default value set.
$this->num_members = -1;
if(TRACK_VISITORS){
/* Calculate number of users at site */
$this->calcNumActiveUsers();
/* Calculate number of guests at site */
$this->calcNumActiveGuests();
* confirmUserPass - Checks whether or not the given
* username is in the database, if so it checks if the
* given password is the same password in the database
* for that user. If the user doesn't exist or if the
* passwords don't match up, it returns an error code
* (1 or 2). On success it returns 0.
function confirmUserPass($username, $password){
/* Add slashes if necessary (for query) */
if(!get_magic_quotes_gpc()) {
$username = addslashes($username);
/* Verify that user is in database */
$q = "SELECT password FROM ".TBL_USERS." WHERE username = '$username'";
$result = mysql_query($q, $this->connection);
if(!$result || (mysql_numrows($result) < 1)){
return 1; //Indicates username failure
/* Retrieve password from result, strip slashes */
$dbarray = mysql_fetch_array($result);
$dbarray['password'] = stripslashes($dbarray['password']);
$password = stripslashes($password);
/* Validate that password is correct */
if($password == $dbarray['password']){
return 0; //Success! Username and password confirmed
else{
return 2; //Indicates password failure
* confirmUserID - Checks whether or not the given
* given userid is the same userid in the database
* userids don't match up, it returns an error code
function confirmUserID($username, $userid){
$q = "SELECT userid FROM ".TBL_USERS." WHERE username = '$username'";
/* Retrieve userid from result, strip slashes */
$dbarray['userid'] = stripslashes($dbarray['userid']);
$userid = stripslashes($userid);
/* Validate that userid is correct */
if($userid == $dbarray['userid']){
return 0; //Success! Username and userid confirmed
else{
return 2; //Indicates userid invalid
* usernameTaken - Returns true if the username has
* been taken by another user, false otherwise.
function usernameTaken($username){
if(!get_magic_quotes_gpc()){
$q = "SELECT username FROM ".TBL_USERS." WHERE username = '$username'";
return (mysql_numrows($result) > 0);
* usernameBanned - Returns true if the username has
* been banned by the administrator.
function usernameBanned($username){
$q = "SELECT username FROM ".TBL_BANNED_USERS." WHERE username = '$username'";
* addNewUser - Inserts the given (username, password, email)
* info into the database. Appropriate user level is set.
* Returns true on success, false otherwise.
function addNewUser($username, $password, $email, $sex, $fname, $lname, $city){
$time = time();
/* If admin sign up, give admin user level */
if(strcasecmp($username, ADMIN_NAME) == 0){
$ulevel = ADMIN_LEVEL;
}else{
$ulevel = USER_LEVEL;
$pic = "i/noavatar.gif";
$q = "INSERT INTO ".TBL_USERS." VALUES ('$username', '$password', '0', $ulevel, '$email', $time, '$fname', '$lname', '$sex', '$pic', '$city', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '', '$pic', '')";
return mysql_query($q, $this->connection);
* updateUserField - Updates a field, specified by the field
* parameter, in the user's row of the database.
function updateUserField($username, $field, $value){
$q = "UPDATE ".TBL_USERS." SET ".$field." = '$value' WHERE username = '$username'";
* getUserInfo - Returns the result array from a mysql
* query asking for all information stored regarding
* the given username. If query fails, NULL is returned.
function getUserInfo($username){
$q = "SELECT * FROM ".TBL_USERS." WHERE username = '$username'";
/* Error occurred, return given name by default */
return NULL;
/* Return result array */
return $dbarray;
* getNumMembers - Returns the number of signed-up users
* of the website, banned members not included. The first
* time the function is called on page load, the database
* is queried, on subsequent calls, the stored result
* is returned. This is to improve efficiency, effectively
* not querying the database when no call is made.
function getNumMembers(){
if($this->num_members < 0){
$q = "SELECT * FROM ".TBL_USERS;
$this->num_members = mysql_numrows($result);
return $this->num_members;
* calcNumActiveUsers - Finds out how many active users
* are viewing site and sets class variable accordingly.
function calcNumActiveUsers(){
$q = "SELECT * FROM ".TBL_ACTIVE_USERS;
$this->num_active_users = mysql_numrows($result);
* calcNumActiveGuests - Finds out how many active guests
function calcNumActiveGuests(){
$q = "SELECT * FROM ".TBL_ACTIVE_GUESTS;
$this->num_active_guests = mysql_numrows($result);
* addActiveUser - Updates username's last active timestamp
* in the database, and also adds him to the table of
* active users, or updates timestamp if already there.
function addActiveUser($username, $time){
$q = "UPDATE ".TBL_USERS." SET timestamp = '$time' WHERE username = '$username'";
if(!TRACK_VISITORS) return;
$q = "REPLACE INTO ".TBL_ACTIVE_USERS." VALUES ('$username', '$time')";
/* addActiveGuest - Adds guest to active guests table */
function addActiveGuest($ip, $time){
$q = "REPLACE INTO ".TBL_ACTIVE_GUESTS." VALUES ('$ip', '$time')";
/* These functions are self explanatory, no need for comments */
/* removeActiveUser */
function removeActiveUser($username){
$q = "DELETE FROM ".TBL_ACTIVE_USERS." WHERE username = '$username'";
/* removeActiveGuest */
function removeActiveGuest($ip){
$q = "DELETE FROM ".TBL_ACTIVE_GUESTS." WHERE ip = '$ip'";
/* removeInactiveUsers */
function removeInactiveUsers(){
$timeout = time()-USER_TIMEOUT*60;
$q = "DELETE FROM ".TBL_ACTIVE_USERS." WHERE timestamp < $timeout";
/* removeInactiveGuests */
function removeInactiveGuests(){
$timeout = time()-GUEST_TIMEOUT*60;
$q = "DELETE FROM ".TBL_ACTIVE_GUESTS." WHERE timestamp < $timeout";
* query - Performs the given query on the database and
* returns the result, which may be false, true or a
* resource identifier.
function query($query){
return mysql_query($query, $this->connection);
/* Create database connection */
$database = new MySQLDB;
