- Проблем при търсачка в база данни
WT форуми -> PHP MySQL ASP.NET -> Проблем при търсачка в база данни
systems
Мнение 10/06/2019 9:34 pm     Проблем при търсачка в база данни Отговорете с цитат
Добър вечер имам следната търсачка но проблема и е че вади всички резултати от базата с данни без да е натиснат бутона за търсене.
ето това е тя:
$conn = mysqli_connect("dbhost", "dbuser", "dbpass", "db");
$with_any_one_of = "";
$with_the_exact_of = "";
$without = "";
$starts_with = "";
$search_in = "";
$advance_search_submit = "";
$queryCondition = "";
if(!empty($_POST["search"])) {
$advance_search_submit = $_POST["advance_search_submit"];
foreach($_POST["search"] as $k=>$v){
if(!empty($v)) {
$queryCases = array("with_any_one_of","with_the_exact_of","without","starts_with");
if(in_array($k,$queryCases)) {
if(!empty($queryCondition)) {
$queryCondition .= " AND ";
$queryCondition .= " WHERE ";
switch($k) {
case "with_any_one_of":
$with_any_one_of = $v;
$wordsAry = explode(" ", $v);
$wordsCount = count($wordsAry);
for($i=0;$i<$wordsCount;$i++) {
if(!empty($_POST["search"]["search_in"])) {
$queryCondition .= $_POST["search"]["search_in"] . " LIKE '%" . $wordsAry[$i] . "%'";
$queryCondition .= "title LIKE '" . $wordsAry[$i] . "%' OR description LIKE '" . $wordsAry[$i] . "%'";
if($i!=$wordsCount-1) {
$queryCondition .= " OR ";
break;
case "with_the_exact_of":
$with_the_exact_of = $v;
$queryCondition .= $_POST["search"]["search_in"] . " LIKE '%" . $v . "%'";
$queryCondition .= "title LIKE '%" . $v . "%' OR description LIKE '%" . $v . "%'";
break;
case "without":
$without = $v;
$queryCondition .= $_POST["search"]["search_in"] . " NOT LIKE '%" . $v . "%'";
$queryCondition .= "title NOT LIKE '%" . $v . "%' AND description NOT LIKE '%" . $v . "%'";
break;
case "starts_with":
$starts_with = $v;
$queryCondition .= $_POST["search"]["search_in"] . " LIKE '" . $v . "%'";
$queryCondition .= "title LIKE '" . $v . "%' OR description LIKE '" . $v . "%'";
break;
case "search_in":
$search_in = $_POST["search"]["search_in"];
break;
$orderby = " ORDER BY id desc";
$sql = "SELECT * FROM links " . $queryCondition;
$result = mysqli_query($conn,$sql);
<html>
<head>
<title>Advanced Search using PHP</title>
<style>
body{
width: 600px;
font-family: "Segoe UI",Optima,Helvetica,Arial,sans-serif;
line-height: 25px;
.search-box {
padding: 30px;
background-color:#C8EEFD;
.search-label{
margin:2px;
.demoInputBox {
padding: 10px;
border: 0;
border-radius: 4px;
margin: 0px 5px 15px;
width: 250px;
.btnSearch{
padding: 10px;
background: #84D2A7;
border: 0;
border-radius: 4px;
margin: 0px 5px;
color: #FFF;
width: 150px;
#advance_search_link {
color: #001FFF;
cursor: pointer;
.result-description{
margin: 5px 0px 15px;
</style>
<script>
function showHideAdvanceSearch() {
if(document.getElementById("advanced-search-box").style.display=="none") {
document.getElementById("advanced-search-box").style.display = "block";
document.getElementById("advance_search_submit").value= "1";
document.getElementById("advanced-search-box").style.display = "none";
document.getElementById("with_the_exact_of").value= "";
document.getElementById("without").value= "";
document.getElementById("starts_with").value= "";
document.getElementById("search_in").value= "";
document.getElementById("advance_search_submit").value= "";
<h2>Advanced Search using PHP</h2>
<div>
<form name="frmSearch" method="post" action="index.php">
<input type="hidden" id="advance_search_submit" name="advance_search_submit" value="<?php echo $advance_search_submit; ?>">
<div class="search-box">
<label class="search-label">With Any One of the Words:</label>
<div>
<input type="text" name="search[with_any_one_of]" class="demoInputBox" value="<?php echo $with_any_one_of; ?>" />
<span id="advance_search_link" onClick="showHideAdvanceSearch()">Advance Search</span>
<div id="advanced-search-box" <?php if(empty($advance_search_submit)) { ?>style="display:none;"<?php } ?>>
<label class="search-label">With the Exact String:</label>
<div>
<input type="text" name="search[with_the_exact_of]" id="with_the_exact_of" class="demoInputBox" value="<?php echo $with_the_exact_of; ?>" />
<label class="search-label">Without:</label>
<div>
<input type="text" name="search[without]" id="without" class="demoInputBox" value="<?php echo $without; ?>" />
<label class="search-label">Starts With:</label>
<div>
<input type="text" name="search[starts_with]" id="starts_with" class="demoInputBox" value="<?php echo $starts_with; ?>" />
<label class="search-label">Search Keywords in:</label>
<div>
<select name="search[search_in]" id="search_in" class="demoInputBox">
<option value="">Select Column</option>
<option value="title" <?php if($search_in=="title") { echo "selected"; } ?>>Title</option>
<option value="description" <?php if($search_in=="description") { echo "selected"; } ?>>Description</option>
</select>
<div>
<input type="submit" name="go" class="btnSearch" value="Search">
<?php while($row = mysqli_fetch_assoc($result)) { ?>
<div>
<div><strong><?php echo $row["title"]; ?></strong></div>
<div class="result-description"><?php echo $row["description"]; ?></div>
<?php } ?>
</html>
опитах с
if (mysqli_num_rows($searchResults) > 0) {
но скрипта продължава да изкарва резултатите без да съм натиснал бутона за търсене.
това и е sql.
CREATE TABLE `links` (
`id` int(Cool NOT NULL,
`title` varchar(255) NOT NULL,
`description` text NOT NULL,
`votes` tinyint(2) DEFAULT '0'
) ENGINE=InnoDB DEFAULT CHARSET=latin1;
Въпроса ми е къде греша и изобщо може ли да се направи да изкарва резултат
само при търсене вместо да изкарва цялата база данни без да е натиснат бутона търсене.
Support: 203
Bonus: 959
Мнение 11/06/2019 11:28 am      Отговорете с цитат
$without = "";
$starts_with = "";
$search_in = "";
$result = false;
if(!empty($v)) {
switch($k) {
break;
break;
case "without":
$without = $v;
break;
case "starts_with":
$starts_with = $v;
break;
case "search_in":
break;
<html>
<head>
<style>
body{
width: 600px;
line-height: 25px;
.search-box {
padding: 30px;
.search-label{
margin:2px;
.demoInputBox {
padding: 10px;
border: 0;
border-radius: 4px;
width: 250px;
.btnSearch{
padding: 10px;
border: 0;
border-radius: 4px;
margin: 0px 5px;
color: #FFF;
width: 150px;
color: #001FFF;
cursor: pointer;
</style>
<script>
<div>
<div>
<div>
<div>
<div>
<div>
</select>
<div>
if($result != false):
while($row = mysqli_fetch_assoc($result)): ?>
<div>
endwhile;
endif; ?>
</html>
Така?
Добавих $result = false;
Сложих другата декларация на $result в if-a ако е постнато.
Доло проверявам ако $result не е false, тогава да fetch-ва.
systems
Мнение 11/06/2019 12:39 pm      Отговорете с цитат
Да сега работи правилно благодаря ви!!!!
