define("VIP", 2);
* page_header.php
* begin : Saturday, Feb 13, 2001
* copyright : (C) 2001 The phpBB Group
* email : support@phpbb.com
* $Id: page_header.php 5283 2005-10-30 15:17:14Z acydburn $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
if ( !defined('IN_PHPBB') )
die("Hacking attempt");
define('HEADER_INC', TRUE);
// gzip_compression
$do_gzip_compress = FALSE;
if ( $board_config['gzip_compress'] )
$phpver = phpversion();
$useragent = (isset($HTTP_SERVER_VARS['HTTP_USER_AGENT'])) ? $HTTP_SERVER_VARS['HTTP_USER_AGENT'] : getenv('HTTP_USER_AGENT');
if ( $phpver >= '4.0.4pl1' && ( strstr($useragent,'compatible') || strstr($useragent,'Gecko') ) )
if ( extension_loaded('zlib') )
ob_start('ob_gzhandler');
else if ( $phpver > '4.0' )
if ( strstr($HTTP_SERVER_VARS['HTTP_ACCEPT_ENCODING'], 'gzip') )
$do_gzip_compress = TRUE;
ob_start();
ob_implicit_flush(0);
header('Content-Encoding: gzip');
// Parse and show the overall header.
$template->set_filenames(array(
'overall_header' => ( empty($gen_simple_header) ) ? 'overall_header.tpl' : 'simple_header.tpl')
// Generate logged in/logged out status
if ( $userdata['session_logged_in'] )
$u_login_logout = 'login.'.$phpEx.'?logout=true&sid=' . $userdata['session_id'];
$l_login_logout = $lang['Logout'] . ' [ ' . $userdata['username'] . ' ]';
$u_login_logout = 'login.'.$phpEx;
$l_login_logout = $lang['Login'];
$s_last_visit = ( $userdata['session_logged_in'] ) ? create_date($board_config['default_dateformat'], $userdata['user_lastvisit'], $board_config['board_timezone']) : '';
// Get basic (usernames + totals) online
// situation
$logged_visible_online = 0;
$logged_hidden_online = 0;
$guests_online = 0;
$online_userlist = '';
$l_online_users = '';
if (defined('SHOW_ONLINE'))
$user_forum_sql = ( !empty($forum_id) ) ? "AND s.session_page = " . intval($forum_id) : '';
$sql = "SELECT u.username, u.user_id, u.user_allow_viewonline, u.user_level, u.user_posts, s.session_logged_in, s.session_ip
FROM ".USERS_TABLE." u, ".SESSIONS_TABLE." s
WHERE u.user_id = s.session_user_id
AND s.session_time >= ".( time() - 300 ) . "
$user_forum_sql
ORDER BY u.username ASC, s.session_ip ASC";
if( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not obtain user/online information', '', __LINE__, __FILE__, $sql);
$userlist_ary = array();
$userlist_visible = array();
$prev_user_id = 0;
$prev_user_ip = $prev_session_ip = '';
while( $row = $db->sql_fetchrow($result) )
// User is logged in and therefor not a guest
if ( $row['session_logged_in'] )
// Skip multiple sessions for one user
if ( $row['user_id'] != $prev_user_id )
$style_color = '';
if ( $row['user_level'] == ADMIN )
$row['username'] = '<b>' . $row['username'] . '</b>';
$style_color = 'style="color:#FF0000"' . $theme['fontcolor3'] . '"';
else if ( $row['user_level'] == MOD )
$style_color = 'style="color:#FFA500"' . $theme['fontcolor2'] . '"';
else if ( $userdata['user_rank'] == VIP )
$style_color = 'style="color:#7c11e0' . $theme['fontcolor2'] . '"';
else if ( $row['user_posts'] > 199 )
$style_color = 'style="color:#9ACD32"';
else if ( $row['user_posts'] > 49 )
$style_color = 'style="color:#3766dd"';
$style_color = 'style="color:#87CEEB"';
