Минимални изисквания за OS
index
Super Moderator
Това е списък с най-често ползваните дистрибуций в Б-я.Информацията не е окончателна и не може напълно да и се рярва.Взета е от различни сайтове.
Не нося никаква отговорност за подадената информация в тази тема !
Windows XP :
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Windows Vista Home :
1 GHz 32-bit (x86) or 64-bit (x64) processor
512 MB of system memory
20 GB hard drive with at least 15 GB of available space
Support for DirectX 9 graphics and 32 MB of graphics memory
DVD-ROM drive
Audio Output
Internet access (fees may apply)
Windows Vista Home Premium / Business / Ultimate :
1 GB of system memory
40 GB hard drive with at least 15 GB of available space
Support for DirectX 9 graphics with:
oWDDM Driver
o128 MB of graphics memory (minimum)
oPixel Shader 2.0 in hardware
o32 bits per pixel
DVD-ROM drive
Audio Output
Windows Seven ( 7 ):
Architecture 32-bit & 64-bit
Processor speed 1 GHz processor
Memory (RAM) 1 GB of RAM (32 bit) & 2 GB of RAM(64 bit)
Graphics card Support for DirectX 9 graphics device with 128MB of graphics memory (for Windows Aero)
HDD free space 16 GB (32 bit) & 20 GB (64 bit) of available disk space
Optical drive DVD drive (only to install from DVD/CD Media)
Ubuntu Desktop Edition (8.10) :
# 300 MHz x86 processor
# 64 MB of system memory (RAM)
# At least 4 GB of disk space (for full installation and swap space)
# VGA graphics card capable of 640x480 resolution
# CD-ROM drive or network card
Ubuntu 9.4:
Install Type |RAM (minimal) |RAM (recommended) |Hard Drive
No desktop |64 megabytes |256 megabytes |1 gigabyte
With Desktop |64 megabytes |512 megabytes |5 gigabytes(става и с 4-ри )
Arch Linux:
* a working knowledge of Linux and your system, especially your
hardware
* Arch Linux installation media (see the mirror list)
+ Arch Linux Install CD
* an i686-based or x86-64 computer (PPro, Pentium 2 or higher, Athlon/Duron,
etc. Note that AMD K6, Transmeta Crusoe, CyrixIII, and VIA-C3 are
NOT supported.)
* 64 MB RAM
* 2 GB Hard Drive
* малко умения
Sabayon Linux:
  • Live Environment - No 3D Desktop:
    • i586 Processor (starting from AMD K5 and Intel Pentium)
    • at least 512MB of RAM (1GB suggested)
    • a 2D graphics card
    • a DDC capable Monitor
    • mouse and keyboard
  • Live Environment - 3D Desktop:
    • i686 Processor (starting from AMD K6 and Intel Pentium II)
    • an OpenGL capable 3D graphics card (mostly NVIDIA, ATI, Intel, VIA)
  • Installation:
    • i586 Processor (see above)
    • at least 512MB of RAM (1GB suggested for decent eyecandy effects)
    • 20GB of free space, that is bare minimum DVD Install. 30+ Gig is recommended
    • 7GB of free space for miniCD. 10+ Gig is recommended
    • Internet connection (not mandatory but highly suggested)
RedHat:
Satellite Requirement: (embedded database)
Pentium IV processor, 2.4 Ghz, 512K cache
Pentium IV processor, 2.4 Ghz dual processor, 512K cache recommended
Disk space and storage:
3 GB storage for base installation of Red Hat Enterprise Linux AS
6 GB storage per channel in /var/satellite directory
12 GB storage for database repository in /rhnsat partition
Separate partition for storing backups
Memory: 2 GB (minimum), 4 GB (recommended)
Slackware Linux:
* 486 processor
* 64MB RAM (1GB+ suggested)
* About 5GB+ of hard disk space for a full install
* CD or DVD drive (if not bootable, then a bootable USB flash stick or PXE server/network card)
PCLinuxOS:
Product PCLinuxOS
Processor Pentium 3 at 700 MHz or better
RAM 256 MB minimum
Drive space 5GB
Drives Runs from hard disk or bootable CD/DVD
Video VGA or better
File systems Ext2, read/write access to FAT/FAT32
OpenSuse 11.2
* Processor: Intel—Pentium 1-4 or Xeon; AMD—Duron, Athlon, Athlon XP, Athlon MP, Athlon 64, Sempron or Opteron
* Main memory: At least 256 MB; 512 MB recommended
* Hard disk: At least 500 MB for minimal system; 3 GB recommended for standard system
* Sound and graphics cards: Supports most modern sound and graphics cards
* DVD-ROM Drive (required for installation from DVD media)
Debian
Install Type RAM (minimal) RAM (recommended) Hard Drive
No desktop 64 megabytes 256 megabytes 1 gigabyte
With Desktop 64 megabytes 512 megabytes 5 gigabytes
Значи, за да се подкара redhat/centos/fedora, се искат пак около 256 MB Ram, просто който тръгне да слага първите два, значи най-вероятно се е насочил към web hosting или подобни и ще са му е нужна доста RAM
Малка промяна в темата.
Всички теми който се отнасят за изискванията на OS към хардуера , да се поставят тук.Същото се отнася и за игрите и приложенията към тях.
