Аз ползвам този клас за да качвам в prikachi.com за lxshotHunteR каза:Ето какво намерих.
http://www.phpclasses.org/browse/package/3753.html
С малко преработка ще стане муцка![]()
alex95_bg_2 каза:Аз ползвам този клас за да качвам в prikachi.com за lxshotHunteR каза:Ето какво намерих.
Там се взима най-лесно линка после
Author: Abhishek Kumar Srivastava
Email: abhisheksrivastava@fastmail.fm
Purpose: The class is written for uploading file using curl
Liscense: GNU GPL
class CurlFileUploader {
var $filePath;
var $uploadURL;
var $formFileVariableName;
var $postParams = array();
/* Constructor for CurlFileUploader
* @param $filePath absolute path of file
* @param $uploadURL url where you want to upload file
* @param $formFileVariableName form field name to upload file
* @param $otherParams assosiative array of other params which you want to send as post
function CurlFileUploader ($filePath, $uploadURL, $formFileVariableName, /* assosiative array */ $otherParams = false) {
$this->filePath = $filePath;
$this->uploadURL = $uploadURL;
if(is_array($otherParams) && $otherParams != false) {
foreach ($otherParams as $fieldName => $fieldValue) {
$this->postParams[$fieldName] = $fieldValue;
$this->postParams[$formFileVariableName] = "@".$filePath;
* function to upload file
* if unable to upload file produce error and exit
* else upload file
function UploadFile () {
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $this->uploadURL );
curl_setopt($ch, CURLOPT_POST, 1 );
print_r($this->postParams);
curl_setopt($ch, CURLOPT_POSTFIELDS, $this->postParams);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
$postResult = curl_exec($ch);
if (curl_errno($ch)) {
print curl_error($ch);
print "<br>Unable to upload file.";
exit();
curl_close($ch);
exit();
Liscense: GNU GPL
var $filePath;
var $uploadURL;
* else upload file
$ch = curl_init();
#print_r($this->postParams);
#print curl_error($ch);
exit();
ТУК ТВОЯ КОД
променливата $postResult ще ти върне страницата в която вече са качени картинките със всички линкове. Твоята задача е просто чрез explode примерно да отделиш това, което ти трябва от тази променлива :)
curl_close($ch);
exit();
$objCurlFileUploader = new CurlFileUploader("D:\\My Pic\\my_pic.jpg", "http://pic-bg.net/upload.php",'userfile[]');
$objCurlFileUploader->UploadFile();
error_reporting(E_ALL);
var $filePath;
var $uploadURL;
* else upload file
$ch = curl_init();
//print_r($this->postParams);
exit();
curl_close($ch);
return $postResult;
//exit();
//print_r($_FILES['file1']);
$tmp = $_FILES['file1']['tmp_name'];
//if (@exif_imagetype($tmp) != IMAGETYPE_PNG) die("lxshot server: bad request");
if($_FILES['file1']['size'] > 2097152) die("lxshot server: image too big. sorry, max 2mb"); //2mb
$name = "shots/".md5(uniqid(rand(), true)).".png";
move_uploaded_file($_FILES['file1']['tmp_name'], $name);
$objCurlFileUploader = new CurlFileUploader($name, "http://www.prikachi.com/index.php",'userfile1', Array('tags' => 'lxshots', 'lock' => 'Checked', 'sent' => 'Качи'));
$out = $objCurlFileUploader->UploadFile();
preg_match('/value="http:\/\/prikachi.com\/files\/(.*).png"/i', $out, $ret);
$id = $ret[1];
echo "http://prikachi.com/files/$id.png\n";
unlink($name);
