<?PHP
error_reporting (E_ALL ^ E_NOTICE);
$cutepath = __FILE__;
$cutepath = preg_replace( "'\\\show_news\.php'", "", $cutepath);
$cutepath = preg_replace( "'/show_news\.php'", "", $cutepath);
require_once("$cutepath/inc/functions.inc.php");
require_once("$cutepath/data/config.php");
// If we are showing RSS, include some need variables.
if($template == 'rss'){
include("$cutepath/data/rss_config.php");
// Check if we are included by PATH
if($_SERVER["HTTP_ACCEPT"] or $_SERVER["HTTP_ACCEPT_CHARSET"] or $_SERVER["HTTP_ACCEPT_ENCODING"] or $_SERVER["HTTP_CONNECTION"]){ /* do nothing */ }
elseif(eregi("show_news.php", $PHP_SELF)){
die("<h4>CuteNews has detected that you are including show_news.php using the URL to this file.<br>
This is incorrect and you must include it using the PATH to show_news.php</h4><br>Example:<br>
this is <font color=red>WRONG</font> : <?PHP include(\"http://yoursite.com/cutenews/show_news.php\"); ?><br>
this is <font color=green>CORRECT</font>: <?PHP include(\"cutenews/show_news.php\"); ?><br>
<br><BR>// <font size=2>if you think this message shouldn't be shown, open show_news.php and delete it from there</font>");
// End of the check
if(!isset($subaction) or $subaction == ""){ $subaction = $POST["subaction"]; }
if(!isset($template) or $template == "" or strtolower($template) == "default"){ require_once("$cutepath/data/Default.tpl"); }
else{
if(file_exists("$cutepath/data/${template}.tpl")){ require("$cutepath/data/${template}.tpl"); }
else{ die("Error!<br>the template <b>".htmlspecialchars($template)."</b> does not exists, note that templates are case sensetive and you must write the name exactly as it is"); }
// Prepare requested categories
if(eregi("[a-z]", $category)){
die("<b>Error</b>!<br>CuteNews has detected that you use \$category = \"".htmlspecialchars($category)."\"; but you can call the categories only with their <b>ID</b> numbers and not with names<br>
example:<br><blockquote><?PHP<br>\$category = \"1\";<br>include(\"path/to/show_news.php\");<br>?></blockquote>");
$category = preg_replace("/ /", "", $category);
$tmp_cats_arr = explode(",", $category);
foreach($tmp_cats_arr as $key=>$value){
if($value != ""){ $requested_cats[$value] = TRUE; }
if($archive == ""){
$news_file = "$cutepath/data/news.txt";
$comm_file = "$cutepath/data/comments.txt";
}else{
$news_file = "$cutepath/data/archives/$archive.news.arch";
$comm_file = "$cutepath/data/archives/$archive.comments.arch";
$allow_add_comment = FALSE;
$allow_full_story = FALSE;
$allow_active_news = FALSE;
$allow_comments = FALSE;
//<<<------------ Detarime what user want to do
if( $CN_HALT != TRUE and $static != TRUE and ($subaction == "showcomments" or $subaction == "showfull" or $subaction == "addcomment") and ((!isset($category) or $category == "") or ($requested_cats[$ucat] == TRUE ) ) ){
if($subaction == "addcomment"){ $allow_add_comment = TRUE; $allow_comments = TRUE; }
if($subaction == "showcomments"){ $allow_comments = TRUE; }
if(($subaction == "showcomments" or $allow_comments == TRUE) and $config_show_full_with_comments == "yes"){$allow_full_story = TRUE; }
if($subaction == "showfull") $allow_full_story = TRUE;
if($subaction == "showfull" and $config_show_comments_with_full == "yes") $allow_comments = TRUE;
else{
if($config_reverse_active == "yes"){ $reverse = TRUE; }
$allow_active_news = TRUE;
//----------->>> Detarime what user want to do
require("$cutepath/inc/shows.inc.php");
if($_GET['archive'] and $_GET['archive'] != ''){ $archive = $_GET['archive']; } // stupid fix ?
unset($static, $template, $requested_cats, $category, $catid, $cat,$reverse, $in_use, $archives_arr, $number, $no_prev, $no_next, $i, $showed, $prev, $used_archives);
// Untamed Edit
// End Edit
