Може ли малко help
Emperator
Иксам да направя ето това :
Ето я и функцията ми :
function local_user()
  return $_SERVER["SERVER_ADDR"] == $_SERVER["REMOTE_ADDR"];
//$FUNDS = "$2,610.31";
$SITE_ONLINE = true;
//$SITE_ONLINE = local_user();
//$SITE_ONLINE = false;
$max_torrent_size = 1000000;
$announce_interval = 60 * 30;
$signup_timeout = 86400 * 3;
$minvotes = 1;
$max_dead_torrent_time = 6 * 3600;
// Max users on site
$maxusers = 75000; // LoL Who we kiddin' here?
$maxusers = 5000;
// ONLY USE ONE OF THE FOLLOWING DEPENDING ON YOUR O/S!!!
$torrent_dir = "torrents";    # FOR UNIX ONLY - must be writable for httpd user
//$torrent_dir = "torrents";    # FOR WINDOWS ONLY - must be writable for httpd user
# the first one will be displayed on the pages
$announce_urls = array();
$announce_urls[] = "http://62.204.129.15/announce.php";
$announce_urls[] = "http://domain.com:82/announce.php";
$announce_urls[] = "http://domain.com:83/announce.php";
if ($_SERVER["HTTP_HOST"] == "")
  $_SERVER["HTTP_HOST"] = $_SERVER["SERVER_NAME"];
$BASEURL = "http://" . $_SERVER["HTTP_HOST"];
// Set this to your site URL... No ending slash!
$DEFAULTBASEURL = "http://domain.com";
//set this to true to make this a tracker that only registered users may use
$MEMBERSONLY = true;
//maximum number of peers (seeders+leechers) allowed before torrents starts to be deleted to make room...
//set this to something high if you don't require this feature
$PEERLIMIT = 50000;
// Email for sender/return path.
$SITEEMAIL = "noreply@domain.com";
$SITENAME = "GMMasterS TorrentS";
$autoclean_interval = 900;
$pic_base_url = "/pic/";
$table_cat = "categories";
require_once("secrets.php");
require_once("cleanup.php");
/**** validip/getip courtesy of manolete <manolete@myway.com> ****/
// IP Validation
function validip($ip)
	if (!empty($ip) && $ip == long2ip(ip2long($ip)))
		// reserved IANA IPv4 addresses
		// http://www.iana.org/assignments/ipv4-address-space
		$reserved_ips = array (
				array('0.0.0.0','2.255.255.255'),
				array('10.0.0.0','10.255.255.255'),
				array('127.0.0.0','127.255.255.255'),
				array('169.254.0.0','169.254.255.255'),
				array('172.16.0.0','172.31.255.255'),
				array('192.0.2.0','192.0.2.255'),
				array('192.168.0.0','192.168.255.255'),
				array('255.255.255.0','255.255.255.255')
		foreach ($reserved_ips as $r)
				$min = ip2long($r[0]);
				$max = ip2long($r[1]);
				if ((ip2long($ip) >= $min) && (ip2long($ip) <= $max)) return false;
		return true;
	else return false;
// Patched function to detect REAL IP address if it's valid
function getip() {
   if (isset($_SERVER)) {
     if (isset($_SERVER['HTTP_X_FORWARDED_FOR']) && validip($_SERVER['HTTP_X_FORWARDED_FOR'])) {
       $ip = $_SERVER['HTTP_X_FORWARDED_FOR'];
     } elseif (isset($_SERVER['HTTP_CLIENT_IP']) && validip($_SERVER['HTTP_CLIENT_IP'])) {
       $ip = $_SERVER['HTTP_CLIENT_IP'];
     if (getenv('HTTP_X_FORWARDED_FOR') && validip(getenv('HTTP_X_FORWARDED_FOR'))) {
       $ip = getenv('HTTP_X_FORWARDED_FOR');
     } elseif (getenv('HTTP_CLIENT_IP') && validip(getenv('HTTP_CLIENT_IP'))) {
       $ip = getenv('HTTP_CLIENT_IP');
       $ip = getenv('REMOTE_ADDR');
   return $ip;
function dbconn($autoclean = false)
    global $mysql_host, $mysql_user, $mysql_pass, $mysql_db;
    if (!@mysql_connect($mysql_host, $mysql_user, $mysql_pass))
	  switch (mysql_errno())
		case 1040:
		case 2002:
			if ($_SERVER[REQUEST_METHOD] == "GET")
				die("<html><head><meta http-equiv=refresh content=\"5 $_SERVER[REQUEST_URI]\"></head><body><table border=0 width=100% height=100%><tr><td><h3 align=center>The server load is very high at the moment. Retrying, please wait...</h3></td></tr></table></body></html>");
				die("Too many users. Please press the Refresh button in your browser to retry.");
        default:
    	    die("[" . mysql_errno() . "] dbconn: mysql_connect: " . mysql_error());
    mysql_select_db($mysql_db)
        or die('dbconn: mysql_select_db: ' + mysql_error());
    userlogin();
    if ($autoclean)
        register_shutdown_function("autoclean");
function userlogin() {
    global $SITE_ONLINE;
    unset($GLOBALS["CURUSER"]);
    $ip = getip();
	$nip = ip2long($ip);
    $res = mysql_query("SELECT * FROM bans WHERE $nip >= first AND $nip <= last") or sqlerr(__FILE__, __LINE__);
    if (mysql_num_rows($res) > 0)
      header("HTTP/1.0 403 Forbidden");
      print("<html><body><h1>403 Forbidden</h1>Unauthorized IP address.</body></html>\n");
      die;
    if (!$SITE_ONLINE || empty($_COOKIE["uid"]) || empty($_COOKIE["pass"]))
        return;
    $id = 0 + $_COOKIE["uid"];
    if (!$id || strlen($_COOKIE["pass"]) != 32)
        return;
    $res = mysql_query("SELECT * FROM users WHERE id = $id AND enabled='yes' AND status = 'confirmed'");// or die(mysql_error());
    $row = mysql_fetch_array($res);
    if (!$row)
        return;
    $sec = hash_pad($row["secret"]);
    if ($_COOKIE["pass"] !== $row["passhash"])
        return;
    mysql_query("UPDATE users SET last_access='" . get_date_time() . "', ip=".sqlesc($ip)." WHERE id=" . $row["id"]);// or die(mysql_error());
    $row['ip'] = $ip;
    $GLOBALS["CURUSER"] = $row;
function autoclean() {
    global $autoclean_interval;
    $now = time();
    $docleanup = 0;
    $res = mysql_query("SELECT value_u FROM avps WHERE arg = 'lastcleantime'");
    if (!$row) {
        mysql_query("INSERT INTO avps (arg, value_u) VALUES ('lastcleantime',$now)");
        return;
    $ts = $row[0];
    if ($ts + $autoclean_interval > $now)
        return;
    mysql_query("UPDATE avps SET value_u=$now WHERE arg='lastcleantime' AND value_u = $ts");
    if (!mysql_affected_rows())
        return;
    docleanup();
function unesc($x) {
    if (get_magic_quotes_gpc())
        return stripslashes($x);
    return $x;
function mksize($bytes)
	if ($bytes < 1000 * 1024)
		return number_format($bytes / 1024, 2) . " kB";
	elseif ($bytes < 1000 * 1048576)
		return number_format($bytes / 1048576, 2) . " MB";
	elseif ($bytes < 1000 * 1073741824)
		return number_format($bytes / 1073741824, 2) . " GB";
		return number_format($bytes / 1099511627776, 2) . " TB";
function mksizeint($bytes)
	$bytes = max(0, $bytes);
	if ($bytes < 1000)
		return floor($bytes) . " B";
	elseif ($bytes < 1000 * 1024)
		return floor($bytes / 1024) . " kB";
		return floor($bytes / 1048576) . " MB";
		return floor($bytes / 1073741824) . " GB";
		return floor($bytes / 1099511627776) . " TB";
function deadtime() {
    global $announce_interval;
    return time() - floor($announce_interval * 1.3);
function mkprettytime($s) {
    if ($s < 0)
        $s = 0;
    $t = array();
    foreach (array("60:sec","60:min","24:hour","0:day") as $x) {
        $y = explode(":", $x);
        if ($y[0] > 1) {
            $v = $s % $y[0];
            $s = floor($s / $y[0]);
            $v = $s;
        $t[$y[1]] = $v;
    if ($t["day"])
        return $t["day"] . "d " . sprintf("%02d:%02d:%02d", $t["hour"], $t["min"], $t["sec"]);
    if ($t["hour"])
        return sprintf("%d:%02d:%02d", $t["hour"], $t["min"], $t["sec"]);
//    if ($t["min"])
        return sprintf("%d:%02d", $t["min"], $t["sec"]);
//    return $t["sec"] . " secs";
function mkglobal($vars) {
    if (!is_array($vars))
        $vars = explode(":", $vars);
    foreach ($vars as $v) {
        if (isset($_GET[$v]))
            $GLOBALS[$v] = unesc($_GET[$v]);
        elseif (isset($_POST[$v]))
            $GLOBALS[$v] = unesc($_POST[$v]);
            return 0;
    return 1;
function tr($x,$y,$noesc=0) {
    if ($noesc)
        $a = $y;
    else {
        $a = htmlspecialchars($y);
        $a = str_replace("\n", "<br />\n", $a);
    print("<tr><td class=\"heading\" valign=\"top\" align=\"right\">$x</td><td valign=\"top\" align=left>$a</td></tr>\n");
function validfilename($name) {
    return preg_match('/^[^\0-\x1f:\\\\\/?*\xff#<>|]+$/si', $name);
function validemail($email) {
    return preg_match('/^[\w.-]+@([\w.-]+\.)+[a-z]{2,6}$/is', $email);
function sqlesc($x) {
    return "'".mysql_real_escape_string($x)."'";
function sqlwildcardesc($x) {
    return str_replace(array("%","_"), array("\\%","\\_"), mysql_real_escape_string($x));
function urlparse($m) {
    $t = $m[0];
    if (preg_match(',^\w+://,', $t))
        return "<a href=\"$t\">$t</a>";
    return "<a href=\"http://$t\">$t</a>";
function parsedescr($d, $html) {
    if (!$html)
      $d = htmlspecialchars($d);
      $d = str_replace("\n", "\n<br>", $d);
    return $d;
function stdhead($title = "", $msgalert = true) {
    global $CURUSER, $SITE_ONLINE, $FUNDS, $SITENAME;
  if (!$SITE_ONLINE)
    die("Site is down for maintenance, please check back again later... thanks<br>");
    header("Content-Type: text/html; charset=windows-1251");
    //header("Pragma: No-cache");
    if ($title == "")
        $title = $SITENAME .(isset($_GET['tbv'])?" (".TBVERSION.")":'');
  if ($CURUSER)
    $ss_a = @mysql_fetch_array(@mysql_query("select uri from stylesheets where id=" . $CURUSER["stylesheet"]));
    if ($ss_a) $ss_uri = $ss_a["uri"];
  if (!$ss_uri)
    ($r = mysql_query("SELECT uri FROM stylesheets WHERE id=1")) or die(mysql_error());
    ($a = mysql_fetch_array($r)) or die(mysql_error());
    $ss_uri = $a["uri"];
  if ($msgalert && $CURUSER)
    $res = mysql_query("SELECT COUNT(*) FROM messages WHERE receiver=" . $CURUSER["id"] . " && unread='yes'") or die("OopppsY!");
    $arr = mysql_fetch_row($res);
    $unread = $arr[0];
<html><head>
<title><?= $title ?></title>
<link rel="stylesheet" href="/<?=$ss_uri?>" type="text/css">
<script type="text/javascript" src="overlib.js"></script>
<script type="text/javascript" src="./imgpopup.js"></script>
<div id="overDiv" style="position:absolute; visibility:hidden; z-index:1000;"></div>
<table width=100% cellspacing=0 cellpadding=0 style='background: transparent'>
</td>
<tr>
    <td class=clear width=49%> <img src="pic/banners/2.jpg"> </td>
    <td class=clear>
      <div align=left><img src="pic/banners/gmmasters10.jpg"> </div></td>
    <td class=clear width=49% align=right>  <img src="pic/banners/1.jpg"> </td>
  </tr>
$w = "width=100%";
//if ($_SERVER["REMOTE_ADDR"] == $_SERVER["SERVER_ADDR"]) $w = "width=984";
<? if ($CURUSER) { ?>
$datum = getdate();
$datum[hours] = sprintf("%02.0f", $datum[hours]);
$datum[minutes] = sprintf("%02.0f", $datum[minutes]);
$uped = mksize($CURUSER['uploaded']);
$downed = mksize($CURUSER['downloaded']);
if ($CURUSER["downloaded"] > 0)
$ratio = $CURUSER['uploaded'] / $CURUSER['downloaded'];
$ratio = number_format($ratio, 3);
$color = get_ratio_color($ratio);
if ($color)
  $ratio = "<font color=$color>$ratio</font>";
if ($CURUSER["uploaded"] > 0)
     $ratio = "Inf.";
$ratio = "---";
if ($CURUSER['donor'] == "yes")
 $medaldon = "<img src=pic/star.gif alt=donor title=donor>";
if ($CURUSER['warned'] == "yes")
 $warn = "<img src=pic/warned.gif alt=warned title=warned>";
//// check for messages //////////////////
$res1 = mysql_query("SELECT COUNT(*) FROM messages WHERE receiver=" . $CURUSER["id"] . " AND location IN ('in', 'both')") or print(mysql_error());
$arr1 = mysql_fetch_row($res1);
$messages = $arr1[0];
$res1 = mysql_query("SELECT COUNT(*) FROM messages WHERE receiver=" . $CURUSER["id"] . " AND location IN ('in', 'both') AND unread='yes'") or print(mysql_error());
$unread = $arr1[0];
$res1 = mysql_query("SELECT COUNT(*) FROM messages WHERE sender=" . $CURUSER["id"] . " AND location IN ('out', 'both')") or print(mysql_error());
$outmessages = $arr1[0];
$res1 = mysql_query("SELECT COUNT(*) FROM messages WHERE receiver=" . $CURUSER["id"] . " && unread='yes'") or die("OopppsY!");
$unread = $arr1[0];
if ($unread)
 $inboxpic = "<img height=14px style=border:none alt=inbox title='inbox (new messages)' src=pic/pn_inboxnew.gif>";
 $inboxpic = "<img height=14px style=border:none alt=inbox title='inbox (no new messages)' src=pic/pn_inbox.gif>";
//// check active torrents ///////////////////////
$res2 = mysql_query("SELECT COUNT(*) FROM peers WHERE userid=" . $CURUSER["id"] . " AND seeder='yes'") or print(mysql_error());
$row = mysql_fetch_row($res2);
$activeseed = $row[0];
$res2 = mysql_query("SELECT COUNT(*) FROM peers WHERE userid=" . $CURUSER["id"] . " AND seeder='no'") or print(mysql_error());
$activeleech = $row[0];
//// end
<table cellpadding="4" cellspacing="1" border="0" style="width:100%">
  <tr>
   <td ><table style="width:100%" cellspacing="0" cellpadding="0" border="0">
    <tr>
     <td class="bottom" align="left"><span class="smallfont">Здравей, <b><a href="userdetails.php?id=<?=$CURUSER['id']?>"><?=$CURUSER['username']?></a></b><?=$medaldon?><?=$warn?>  [<a href="logout.php">Изход</a>]<? if (get_user_class() >= UC_MODERATOR) { ?> [<a href="adminpanel.php">Контролен Панел</a>] <?}?><br/>
     <font color=1900D1>Коефициент:</font> <?=$ratio?>  <font color=green>Каил:</font> <font color=black><?=$uped?></font>  <font color=darkred>Свалил:</font> <font color=black><?=$downed?></font>  <font color=1900D1>Активни торенти: </font></span> <img alt="Torrents seeding" title="В момента сийдва" src="pic/arrowup.gif"> <font color=black><span class="smallfont"><?=$activeseed?></span></font>  <img alt="Torrents leeching" title="В момента личва" src="pic/arrowdown.gif"> <font color=black><span class="smallfont"><?=$activeleech?></span></font></td>
     <td class="bottom" align="right"><span class="smallfont">Часа в момента е: <?echo "$datum[hours]:$datum[minutes]";?><br/>
       if ($messages){
               print("<span class=smallfont><a href=inbox.php>$inboxpic</a> $messages ($unread нов(и))</span>");
  if ($outmessages)
     print("<span class=smallfont>  <a href=inbox.php?out=1><img height=14px style=border:none alt=sentbox title=sentbox src=pic/pn_sentbox.gif></a> $outmessages</span>");
     print("<span class=smallfont>  <a href=inbox.php?out=1><img height=14px style=border:none alt=sentbox title=sentbox src=pic/pn_sentbox.gif></a> 0</span>");
               print("<span class=smallfont><a href=inbox.php><img height=14px style=border:none alt=inbox title=inbox src=pic/pn_inbox.gif></a> 0</span>");
  if ($outmessages)
       print(" <a href=friends.php><img style=border:none alt=Buddylist title=Приятели src=pic/buddylist.gif></a>");
     </span></td>
    </tr>
   </table></table>
   <p>
<br>
<table class=mainouter <?=$w; ?> border="1" cellspacing="0" cellpadding="10">
<? $fn = substr($_SERVER['PHP_SELF'], strrpos($_SERVER['PHP_SELF'], "/") + 1); ?>
<tr><td class=outer align=center>
<table class=main width=700 cellspacing="0" cellpadding="5" border="0">
<tr>
<? if($CURUSER){ ?>
<tr>
<td align="center" class="navigation"><a href=/><img src="pic/gm/home.png"><br>Начало</a> </td>
<td align="center" class="navigation"><a href=/browse.php><img src="pic/gm/torrents.png"><br>Торенти</a> </td>
<td align="center" class="navigation"><a href=/upload.php><img src="pic/gm/upload.png"><br>Качи</a> </td>
<td align="center" class="navigation"><a href=/my.php><img src="pic/gm/my.png"><br>Профил</a> </td>
<td align="center" class="navigation"><a href=/viewrequests.php><img src="pic/gm/reguest.png"><br>Заявки</a> </td>
<td align="center" class="navigation"><a href=/banners.php><font color=blue><img src="pic/gm/banners.png"><br>Реклама</font></a></li></a> </td>
<td align="center" class="navigation"><a href=/forums.php><img src="pic/gm/forum.png"><br>Форум</a> </td>
<td align="center" class="navigation"><a href=/catalogue.php><img src="pic/gm/catalogue.png"><br>Каталог</a> </td>
<td align="center" class="navigation"><a href=/topten.php><img src="pic/gm/topten.png"><br>Toп10</a> </td>
<td align="center" class="navigation"><a href=/rules.php><img src="pic/gm/rules.png"><br>Правила</a> </td>
<td align="center" class="navigation"><a href=/faq.php><img src="pic/gm/faq.png"><br>FAQ</a> </td>
<td align="center" class="navigation"><a href=/helpdesk.php><img src="pic/gm/helpdesk.png"><br>Помощ</a> </td>
<td align="center" class="navigation"><a href=/links.php><img src="pic/gm/links.png"><br>Линкове</a> </td>
<td align="center" class="navigation"><a href=/donate.php><img src="pic/gm/donate.png"><br>SMS-HelP</a> </td>
<td align="center" class="navigation"><a href=/staff.php><img src="pic/gm/support.png"><br>Еикп</a> </td>
<td align="center" class="navigation"><a href=/logout.php><font color=red><img src="pic/gm/exit.png"><br>Иход</font></a></li></a> </td>
</tr>
<? } else {?>
<center><font color=orange><b>Внимание:</b></front><font color=red> За да виждате страниците,трябва да се логнете в сайта!        <a href="signup.php">Регистрация</a> | <a href="login.php">Вход</a> | <a href="faq.php">FAQ</a></front></center>
</tr>
</table>
</td>
</tr>
<tr><td align=center class=outer style="padding-top: 20px; padding-bottom: 20px">
<span style="float: left;"><img src="pic/banners/left.jpg" width="110" height="240" border="0" alt="Amour4e.com Намерете вашия приател!"><br><br>
<img src="pic/banners/3.jpg" width="110" height="90" border="0" alt="Amour4e.com Намерете вашия приател!">
 </span>
</a> </span>
<span style="float: right;"><img src="pic/banners/right.jpg" width="110" height="240" border="0" alt="Amour4e.com Намерете вашия приател!"> <br><br>
<img src="pic/banners/4.jpg" width="110" height="90" border="0" alt="Amour4e.com Намерете вашия приател!"> </span>
<img src="pic/banners/banner.jpg" alt="Рекламирай тук!" border="0">
<br>
if ($unread)
  print("<p><table border=0 cellspacing=0 cellpadding=10 bgcolor=red><tr><td style='padding: 10px; background: red'>\n");
  print("<b><a href=$BASEURL/inbox.php><font color=white>You have $unread new message" . ($unread > 1 ? "s" : "") . "!</font></a></b>");
  print("</td></tr></table></p>\n");
} // stdhead
function stdfoot() {
  print("</td></tr></table>\n");
  print("<table class=bottom width=100% border=0 cellspacing=0 cellpadding=0><tr valign=top>\n");
  print("</tr></table>\n");
  print("</body></html>\n");
function genbark($x,$y) {
    stdhead($y);
    print("<h2>" . htmlspecialchars($y) . "</h2>\n");
    print("<p>" . htmlspecialchars($x) . "</p>\n");
    stdfoot();
    exit();
function mksecret($len = 20) {
    $ret = "";
    for ($i = 0; $i < $len; $i++)
        $ret .= chr(mt_rand(0, 255));
    return $ret;
function httperr($code = 404) {
    header("HTTP/1.0 404 Not found");
    print("<h1>Not Found</h1>\n");
    print("<p>Sorry pal :(</p>\n");
    exit();
function gmtime()
    return strtotime(get_date_time());
function logincookie($id, $password, $secret, $updatedb = 1, $expires = 0x7fffffff) {
    $md5 = md5($secret . $password . $secret);
    setcookie("uid", $id, $expires, "/");
    setcookie("pass", $md5, $expires, "/");
    if ($updatedb)
        mysql_query("UPDATE users SET last_login = NOW() WHERE id = $id");
function logincookie($id, $passhash, $updatedb = 1, $expires = 0x7fffffff)
	setcookie("pass", $passhash, $expires, "/");
  if ($updatedb)
function logoutcookie() {
    setcookie("uid", "", 0x7fffffff, "/");
    setcookie("pass", "", 0x7fffffff, "/");
function loggedinorreturn() {
    global $CURUSER;
    if (!$CURUSER) {
        header("Location: $BASEURL/login.php?returnto=" . urlencode($_SERVER["REQUEST_URI"]));
        exit();
function deletetorrent($id) {
    global $torrent_dir;
    mysql_query("DELETE FROM torrents WHERE id = $id");
    foreach(explode(".","peers.files.comments.ratings") as $x)
        mysql_query("DELETE FROM $x WHERE torrent = $id");
    unlink("$torrent_dir/$id.torrent");
function pager($rpp, $count, $href, $opts = array()) {
    $pages = ceil($count / $rpp);
    if (!$opts["lastpagedefault"])
        $pagedefault = 0;
    else {
        $pagedefault = floor(($count - 1) / $rpp);
        if ($pagedefault < 0)
            $pagedefault = 0;
    if (isset($_GET["page"])) {
        $page = 0 + $_GET["page"];
        if ($page < 0)
            $page = $pagedefault;
    $pager = "";
    $mp = $pages - 1;
    $as = "<b><< Назад</b>";
    if ($page >= 1) {
        $pager .= "<a href=\"{$href}page=" . ($page - 1) . "\">";
        $pager .= $as;
        $pager .= "</a>";
        $pager .= $as;
    $pager .= "      ";
    $as = "<b>Напред >></b>";
    if ($page < $mp && $mp >= 0) {
        $pager .= "<a href=\"{$href}page=" . ($page + 1) . "\">";
        $pager .= $as;
        $pager .= "</a>";
        $pager .= $as;
    if ($count) {
        $pagerarr = array();
        $dotted = 0;
        $dotspace = 3;
        $dotend = $pages - $dotspace;
        $curdotend = $page - $dotspace;
        $curdotstart = $page + $dotspace;
        for ($i = 0; $i < $pages; $i++) {
            if (($i >= $dotspace && $i <= $curdotend) || ($i >= $curdotstart && $i < $dotend)) {
                if (!$dotted)
                    $pagerarr[] = "...";
                $dotted = 1;
                continue;
            $dotted = 0;
            $start = $i * $rpp + 1;
            $end = $start + $rpp - 1;
            if ($end > $count)
                $end = $count;
            $text = "$start - $end";
            if ($i != $page)
                $pagerarr[] = "<a href=\"{$href}page=$i\"><b>$text</b></a>";
                $pagerarr[] = "<b>$text</b>";
        $pagerstr = join(" | ", $pagerarr);
        $pagertop = "<p align=\"center\">$pager<br />$pagerstr</p>\n";
        $pagerbottom = "<p align=\"center\">$pagerstr<br />$pager</p>\n";
    else {
        $pagertop = "<p align=\"center\">$pager</p>\n";
        $pagerbottom = $pagertop;
    $start = $page * $rpp;
    return array($pagertop, $pagerbottom, "LIMIT $start,$rpp");
function downloaderdata($res) {
    $rows = array();
    $ids = array();
    $peerdata = array();
    while ($row = mysql_fetch_assoc($res)) {
        $rows[] = $row;
        $id = $row["id"];
        $ids[] = $id;
        $peerdata[$id] = array(downloaders => 0, seeders => 0, comments => 0);
    if (count($ids)) {
        $allids = implode(",", $ids);
        $res = mysql_query("SELECT COUNT(*) AS c, torrent, seeder FROM peers WHERE torrent IN ($allids) GROUP BY torrent, seeder");
            if ($row["seeder"] == "yes")
                $key = "seeders";
                $key = "downloaders";
            $peerdata[$row["torrent"]][$key] = $row["c"];
        $res = mysql_query("SELECT COUNT(*) AS c, torrent FROM comments WHERE torrent IN ($allids) GROUP BY torrent");
            $peerdata[$row["torrent"]]["comments"] = $row["c"];
    return array($rows, $peerdata);
function commenttable($rows)
	global $CURUSER;
	begin_main_frame();
	begin_frame();
	$count = 0;
	foreach ($rows as $row)
		print("<p class=sub>#" . $row["id"] . " by ");
    if (isset($row["username"]))
			$title = $row["title"];
			if ($title == "")
				$title = get_user_class_name($row["class"]);
				$title = htmlspecialchars($title);
        print("<a name=comm". $row["id"] .
        	" href=userdetails.php?id=" . $row["user"] . "><b>" .
        	htmlspecialchars($row["username"]) . "</b></a>" . ($row["donor"] == "yes" ? "<img src=pic/star.gif alt='Donor'>" : "") . ($row["warned"] == "yes" ? "<img src=".
    			"/pic/warned.gif alt=\"Warned\">" : "") . " ($title)\n");
   		print("<a name=\"comm" . $row["id"] . "\"><i>(orphaned)</i></a>\n");
		print(" at " . $row["added"] . " GMT" .
			($row["user"] == $CURUSER["id"] || get_user_class() >= UC_MODERATOR ? "- [<a href=comment.php?action=edit&cid=$row[id]>Edit</a>]" : "") .
			(get_user_class() >= UC_MODERATOR ? "- [<a href=comment.php?action=delete&cid=$row[id]>Delete</a>]" : "") .
			($row["editedby"] && get_user_class() >= UC_MODERATOR ? "- [<a href=comment.php?action=vieworiginal&cid=$row[id]>View original</a>]" : "") . "</p>\n");
		$avatar = ($CURUSER["avatars"] == "yes" ? htmlspecialchars($row["avatar"]) : "");
		if (!$avatar)
			$avatar = "/pic/default_avatar.gif";
		$text = format_comment($row["text"]);
    if ($row["editedby"])
    	$text .= "<p><font size=1 class=small>Last edited by <a href=userdetails.php?id=$row[editedby]><b>$row[username]</b></a> at $row[editedat] GMT</font></p>\n";
		begin_table(true);
		print("<tr valign=top>\n");
		print("<td align=center width=150 style='padding: 0px'><img width=150 src=$avatar></td>\n");
		print("<td class=text>$text</td>\n");
		print("</tr>\n");
     end_table();
	end_frame();
	end_main_frame();
function searchfield($s) {
    return preg_replace(array('/[^a-z0-9]/si', '/^\s*/s', '/\s*$/s', '/\s+/s'), array(" ", "", "", " "), $s);
function genrelist() {
    $ret = array();
    $res = mysql_query("SELECT id, name FROM categories ORDER BY name");
    while ($row = mysql_fetch_array($res))
        $ret[] = $row;
    return $ret;
function linkcolor($num) {
    if (!$num)
        return "red";
//    if ($num == 1)
//        return "yellow";
    return "green";
function ratingpic($num) {
    global $pic_base_url;
    $r = round($num * 2) / 2;
    if ($r < 1 || $r > 5)
        return;
    return "<img src=\"$pic_base_url$r.gif\" border=\"0\" alt=\"rating: $num / 5\" />";
function torrenttable($res, $variant = "index") {
	global $pic_base_url, $CURUSER;
	if ($CURUSER["class"] < UC_VIP)
	  $gigs = $CURUSER["uploaded"] / (1024*1024*1024);
	  $ratio = (($CURUSER["downloaded"] > 0) ? ($CURUSER["uploaded"] / $CURUSER["downloaded"]) : 0);
	  if ($ratio < 0.5 || $gigs < 5) $wait = 48;
	  elseif ($ratio < 0.65 || $gigs < 6.5) $wait = 24;
	  elseif ($ratio < 0.8 || $gigs < 8) $wait = 12;
	  elseif ($ratio < 0.95 || $gigs < 9.5) $wait = 6;
	  else $wait = 0;
<table border="1" cellspacing=0 cellpadding=5>
<tr>
<td class="colhead" align="center">Вид</td>
<td class="colhead" align=left>Име</td>
	if ($wait)
		print("<td class=\"colhead\" align=\"center\">Wait</td>\n");
	if ($variant == "mytorrents")
  	print("<td class=\"colhead\" align=\"center\">Edit</td>\n");
    print("<td class=\"colhead\" align=\"center\">Visible</td>\n");
<td class="colhead" align=right>Файла</td>
<td class="colhead" align=right>Ком.</td>
<td class="colhead" align="center">Рейтинг</td>
<td class="colhead" align="center">Качен</td>
<td class="colhead" align="center">TTL</td>
<td class="colhead" align="center">Размер</td>
<td class="colhead" align="center">Изтеглен</td>
<td class="colhead" align=right>Сийдъри</td>
<td class="colhead" align=right>Лийчъри</td>
    if ($variant == "index")
        print("<td class=\"colhead\" align=center>Качен от</td>\n");
    print("</tr>\n");
        $id = $row["id"];
        print("<tr>\n");
        print("<td align=center style='padding: 0px'>");
        if (isset($row["cat_name"])) {
            print("<a href=\"browse.php?cat=" . $row["category"] . "\">");
            if (isset($row["cat_pic"]) && $row["cat_pic"] != "")
                print("<img border=\"0\" src=\"$pic_base_url" . $row["cat_pic"] . "\" alt=\"" . $row["cat_name"] . "\" />");
                print($row["cat_name"]);
            print("</a>");
            print("-");
        print("</td>\n");
            /////BG SUBS MOD BY  B.U.S.T.T.E.R.\\\\\\\\\\\\
			#DO NOT EDIT!!!
		   /////BG SUBS database check start
			$bgsubs_res = mysql_query("SELECT bgsubs FROM torrents WHERE id=$id") or
             $bgsubs_row = mysql_fetch_assoc($bgsubs_res);
			 ####BG SUBS database check stop
/////BG AUDIO MOD BY B.U.S.T.T.E.R. \\\\\\\\\\\\
			#DO NOT EDIT!!!
		   /////BG AUDIO database check start
			$bgaudio_res = mysql_query("SELECT bgaudio FROM torrents WHERE id=$id") or
             $bgaudio_row = mysql_fetch_assoc($bgaudio_res);
			 ####BG AUDIO database check stop
			 //BG SUBS by B.U.S.T.T.E.R.  shows  if database return yes\\\\
			  if ($bgsubs_row["bgsubs"] == "yes"){
                 $bgsub = "<img src=".$BASEURL."/pic/subs.gif border=0>";
//BG AUDIO by B.U.S.T.T.E.R.  shows  if database return yes\\\\
			  if ($bgaudio_row["bgaudio"] == "yes"){
                  $bgaud = "<img src=".$BASEURL."/pic/bgaudio.gif border=0>";
        $preparing_baloon=mysql_query("SELECT poster FROM torrents WHERE id=$id LIMIT 0, 255") or sqlerr();
$poster=mysql_fetch_array($preparing_baloon);
$poster=$poster[poster];
$preparing_descr=mysql_query("SELECT descr FROM torrents WHERE id=$id LIMIT 0, 1 ") or sqlerr();
$des=ereg_replace("<","<",$des);
$des=ereg_replace(">",">",$des);
$des=ereg_replace(" "," ",$des);
$des=ereg_replace("
","<br>",$des);
$dispname = htmlspecialchars($row["name"]);
$baloon=
print("<td align=left><a href=details.php?id=$id onmouseover=\"return overlib('<table width=100%><tr><td>$bgsub $bgaud<br><img src=$poster width=150 height=200></td><td>$des</td></tr></table>',  WIDTH, 140, DELAY, 200);\" onmouseout=\"return nd();\";><b>$dispname</b></a><br>$description");
        print("<td align=left><a href=\"details.php?");
            print("returnto=" . urlencode($_SERVER["REQUEST_URI"]) . "&");
        print("id=$id");
            print("&hit=1");
				if ($wait)
				  $elapsed = floor((gmtime() - strtotime($row["added"])) / 3600);
	        if ($elapsed < $wait)
	          $color = dechex(floor(127*($wait - $elapsed)/48 + 128)*65536);
	          print("<td align=center><nobr><a href=\"/faq.php#dl8\"><font color=\"$color\">" . number_format($wait - $elapsed) . " h</font></a></nobr></td>\n");
	          print("<td align=center><nobr>None</nobr></td>\n");
        if ($row["nfoav"] && get_user_class() >= UC_POWER_USER)
          print("<a href=viewnfo.php?id=$row[id]><img src=pic/viewnfo.gif border=0 alt='View NFO'></a>\n");
            print("<a href=\"download.php/$id/" . rawurlencode($row["filename"]) . "\"><img src=pic/download.gif border=0 alt=Download></a>\n");
        else */ if ($variant == "mytorrents")
            print("<td align=\"center\"><a href=\"edit.php?returnto=" . urlencode($_SERVER["REQUEST_URI"]) . "&id=" . $row["id"] . "\">edit</a>\n");
print("</td>\n");
        if ($variant == "mytorrents") {
            print("<td align=\"right\">");
            if ($row["visible"] == "no")
                print("<b>no</b>");
                print("yes");
            print("</td>\n");
        if ($row["type"] == "single")
            print("<td align=\"right\">" . $row["numfiles"] . "</td>\n");
        else {
                print("<td align=\"right\"><b><a href=\"details.php?id=$id&hit=1&filelist=1\">" . $row["numfiles"] . "</a></b></td>\n");
                print("<td align=\"right\"><b><a href=\"details.php?id=$id&filelist=1#filelist\">" . $row["numfiles"] . "</a></b></td>\n");
        if (!$row["comments"])
            print("<td align=\"right\">" . $row["comments"] . "</td>\n");
        else {
                print("<td align=\"right\"><b><a href=\"details.php?id=$id&hit=1&tocomm=1\">" . $row["comments"] . "</a></b></td>\n");
                print("<td align=\"right\"><b><a href=\"details.php?id=$id&page=0#startcomments\">" . $row["comments"] . "</a></b></td>\n");
        print("<td align=\"center\">");
        if (!isset($row["rating"]))
            print("---");
        else {
            $rating = round($row["rating"] * 2) / 2;
            $rating = ratingpic($row["rating"]);
            if (!isset($rating))
                print("---");
                print($rating);
        print("</td>\n");
        print("<td align=center><nobr>" . str_replace(" ", "<br />", $row["added"]) . "</nobr></td>\n");
		$ttl = (28*24) - floor((gmtime() - sql_timestamp_to_unix_timestamp($row["added"])) / 3600);
		if ($ttl == 1) $ttl .= "<br>hour"; else $ttl .= "<br>hours";
        print("<td align=center>$ttl</td>\n");
        print("<td align=center>" . str_replace(" ", "<br>", mksize($row["size"])) . "</td>\n");
//        print("<td align=\"right\">" . $row["views"] . "</td>\n");
//        print("<td align=\"right\">" . $row["hits"] . "</td>\n");
        $_s = "";
        if ($row["times_completed"] != 1)
          $_s = "s";
        print("<td align=center>" . number_format($row["times_completed"]) . "<br>time$_s</td>\n");
        if ($row["seeders"]) {
               if ($row["leechers"]) $ratio = $row["seeders"] / $row["leechers"]; else $ratio = 1;
                print("<td align=right><b><a href=details.php?id=$id&hit=1&toseeders=1><font color=" .
                  get_slr_color($ratio) . ">" . $row["seeders"] . "</font></a></b></td>\n");
                print("<td align=\"right\"><b><a class=\"" . linkcolor($row["seeders"]) . "\" href=\"details.php?id=$id&dllist=1#seeders\">" .
                  $row["seeders"] . "</a></b></td>\n");
            print("<td align=\"right\"><span class=\"" . linkcolor($row["seeders"]) . "\">" . $row["seeders"] . "</span></td>\n");
        if ($row["leechers"]) {
                print("<td align=right><b><a href=details.php?id=$id&hit=1&todlers=1>" .
                   number_format($row["leechers"]) . ($peerlink ? "</a>" : "") .
                   "</b></td>\n");
                print("<td align=\"right\"><b><a class=\"" . linkcolor($row["leechers"]) . "\" href=\"details.php?id=$id&dllist=1#leechers\">" .
                  $row["leechers"] . "</a></b></td>\n");
            print("<td align=\"right\">0</td>\n");
            print("<td align=center>" . (isset($row["username"]) ? ("<a href=userdetails.php?id=" . $row["owner"] . "><b>" . htmlspecialchars($row["username"]) . "</b></a>") : "<i>(unknown)</i>") . "</td>\n");
        print("</tr>\n");
    print("</table>\n");
    return $rows;
function hash_pad($hash) {
    return str_pad($hash, 20);
function hash_where($name, $hash) {
    $shhash = preg_replace('/ *$/s', "", $hash);
    return "($name = " . sqlesc($hash) . " OR $name = " . sqlesc($shhash) . ")";
function get_user_icons($arr, $big = false)
	if ($big)
		$donorpic = "starbig.gif";
		$warnedpic = "warnedbig.gif";
		$disabledpic = "disabledbig.gif";
		$style = "style='margin-left: 4pt'";
		$donorpic = "star.gif";
		$warnedpic = "warned.gif";
		$disabledpic = "disabled.gif";
		$style = "style=\"margin-left: 2pt\"";
	$pics = $arr["donor"] == "yes" ? "<img src=pic/$donorpic alt='Donor' border=0 $style>" : "";
	if ($arr["enabled"] == "yes")
		$pics .= $arr["warned"] == "yes" ? "<img src=pic/$warnedpic alt=\"Warned\" border=0 $style>" : "";
		$pics .= "<img src=pic/$disabledpic alt=\"Disabled\" border=0 $style>\n";
	return $pics;
require "global.php";
