Може ли файловете memberlist.php и memberlist_body.tpl ?
* memberlist.php
* begin : Friday, May 11, 2001
* copyright : (C) 2001 The phpBB Group
* email : support@phpbb.com
* $Id: memberlist.php,v 1.36.2.13 2006/12/16 13:11:24 acydburn Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
// Start session management
$userdata = session_pagestart($user_ip, PAGE_VIEWMEMBERS);
init_userprefs($userdata);
// End session management
$start = ( isset($HTTP_GET_VARS['start']) ) ? intval($HTTP_GET_VARS['start']) : 0;
$start = ($start < 0) ? 0 : $start;
if ( isset($HTTP_GET_VARS['mode']) || isset($HTTP_POST_VARS['mode']) )
$mode = ( isset($HTTP_POST_VARS['mode']) ) ? htmlspecialchars($HTTP_POST_VARS['mode']) : htmlspecialchars($HTTP_GET_VARS['mode']);
$mode = 'joined';
if(isset($HTTP_POST_VARS['order']))
$sort_order = ($HTTP_POST_VARS['order'] == 'ASC') ? 'ASC' : 'DESC';
else if(isset($HTTP_GET_VARS['order']))
$sort_order = ($HTTP_GET_VARS['order'] == 'ASC') ? 'ASC' : 'DESC';
$sort_order = 'ASC';
// Memberlist sorting
$mode_types_text = array($lang['Sort_Joined'], $lang['Sort_Username'], $lang['Sort_Location'], $lang['Sort_Posts'], $lang['Sort_Email'], $lang['Sort_Website'], $lang['Sort_Top_Ten']);
$mode_types = array('joined', 'username', 'location', 'posts', 'email', 'website', 'topten');
$select_sort_mode = '<select name="mode">';
for($i = 0; $i < count($mode_types_text); $i++)
$selected = ( $mode == $mode_types[$i] ) ? ' selected="selected"' : '';
$select_sort_mode .= '<option value="' . $mode_types[$i] . '"' . $selected . '>' . $mode_types_text[$i] . '</option>';
$select_sort_mode .= '</select>';
$select_sort_order = '<select name="order">';
if($sort_order == 'ASC')
$select_sort_order .= '<option value="ASC" selected="selected">' . $lang['Sort_Ascending'] . '</option><option value="DESC">' . $lang['Sort_Descending'] . '</option>';
$select_sort_order .= '<option value="ASC">' . $lang['Sort_Ascending'] . '</option><option value="DESC" selected="selected">' . $lang['Sort_Descending'] . '</option>';
$select_sort_order .= '</select>';
// Generate page
$page_title = $lang['Memberlist'];
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
$template->set_filenames(array(
'body' => 'memberlist_body.tpl')
make_jumpbox('viewforum.'.$phpEx);
$template->assign_vars(array(
'L_SELECT_SORT_METHOD' => $lang['Select_sort_method'],
'L_EMAIL' => $lang['Email'],
'L_WEBSITE' => $lang['Website'],
'L_FROM' => $lang['Location'],
'L_ORDER' => $lang['Order'],
'L_SORT' => $lang['Sort'],
'L_SUBMIT' => $lang['Sort'],
'L_AIM' => $lang['AIM'],
'L_YIM' => $lang['YIM'],
'L_MSNM' => $lang['MSNM'],
'L_ICQ' => $lang['ICQ'],
'L_JOINED' => $lang['Joined'],
'L_POSTS' => $lang['Posts'],
'L_PM' => $lang['Private_Message'],
'S_MODE_SELECT' => $select_sort_mode,
'S_ORDER_SELECT' => $select_sort_order,
'S_MODE_ACTION' => append_sid("memberlist.$phpEx"))
switch( $mode )
case 'joined':
$order_by = "user_regdate $sort_order LIMIT $start, " . $board_config['topics_per_page'];
break;
case 'username':
$order_by = "username $sort_order LIMIT $start, " . $board_config['topics_per_page'];
break;
case 'location':
$order_by = "user_from $sort_order LIMIT $start, " . $board_config['topics_per_page'];
break;
case 'posts':
$order_by = "user_posts $sort_order LIMIT $start, " . $board_config['topics_per_page'];
break;
case 'email':
$order_by = "user_email $sort_order LIMIT $start, " . $board_config['topics_per_page'];
break;
case 'website':
$order_by = "user_website $sort_order LIMIT $start, " . $board_config['topics_per_page'];
break;
case 'topten':
$order_by = "user_posts $sort_order LIMIT 10";
break;
default:
break;
$sql = "SELECT username, user_id, user_viewemail, user_posts, user_regdate, user_from, user_website, user_email, user_icq, user_aim, user_yim, user_msnm, user_avatar, user_avatar_type, user_allowavatar
FROM " . USERS_TABLE . "
WHERE user_id <> " . ANONYMOUS . "
ORDER BY $order_by";
if( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not query users', '', __LINE__, __FILE__, $sql);
if ( $row = $db->sql_fetchrow($result) )
$i = 0;
do
$username = $row['username'];
$user_id = $row['user_id'];
$from = ( !empty($row['user_from']) ) ? $row['user_from'] : ' ';
$joined = create_date($lang['DATE_FORMAT'], $row['user_regdate'], $board_config['board_timezone']);
$posts = ( $row['user_posts'] ) ? $row['user_posts'] : 0;
$poster_avatar = '';
if ( $row['user_avatar_type'] && $user_id != ANONYMOUS && $row['user_allowavatar'] )
switch( $row['user_avatar_type'] )
case USER_AVATAR_UPLOAD:
$poster_avatar = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $row['user_avatar'] . '" alt="" border="0" />' : '';
break;
case USER_AVATAR_REMOTE:
$poster_avatar = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $row['user_avatar'] . '" alt="" border="0" />' : '';
break;
case USER_AVATAR_GALLERY:
$poster_avatar = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $row['user_avatar'] . '" alt="" border="0" />' : '';
break;
if ( !empty($row['user_viewemail']) || $userdata['user_level'] == ADMIN )
$email_uri = ( $board_config['board_email_form'] ) ? append_sid("profile.$phpEx?mode=email&" . POST_USERS_URL .'=' . $user_id) : 'mailto:' . $row['user_email'];
$email_img = '<a href="' . $email_uri . '"><img src="' . $images['icon_email'] . '" alt="' . $lang['Send_email'] . '" title="' . $lang['Send_email'] . '" border="0" /></a>';
$email = '<a href="' . $email_uri . '">' . $lang['Send_email'] . '</a>';
$email_img = ' ';
$email = ' ';
$temp_url = append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$user_id");
$profile_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_profile'] . '" alt="' . $lang['Read_profile'] . '" title="' . $lang['Read_profile'] . '" border="0" /></a>';
$profile = '<a href="' . $temp_url . '">' . $lang['Read_profile'] . '</a>';
$temp_url = append_sid("privmsg.$phpEx?mode=post&" . POST_USERS_URL . "=$user_id");
$pm_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_pm'] . '" alt="' . $lang['Send_private_message'] . '" title="' . $lang['Send_private_message'] . '" border="0" /></a>';
$pm = '<a href="' . $temp_url . '">' . $lang['Send_private_message'] . '</a>';
$www_img = ( $row['user_website'] ) ? '<a href="' . $row['user_website'] . '" target="_userwww"><img src="' . $images['icon_www'] . '" alt="' . $lang['Visit_website'] . '" title="' . $lang['Visit_website'] . '" border="0" /></a>' : '';
$www = ( $row['user_website'] ) ? '<a href="' . $row['user_website'] . '" target="_userwww">' . $lang['Visit_website'] . '</a>' : '';
if ( !empty($row['user_icq']) )
$icq_status_img = '<a href="http://wwp.icq.com/' . $row['user_icq'] . '#pager"><img src="http://web.icq.com/whitepages/online?icq=' . $row['user_icq'] . '&img=5" width="18" height="18" border="0" /></a>';
$icq_img = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $row['user_icq'] . '"><img src="' . $images['icon_icq'] . '" alt="' . $lang['ICQ'] . '" title="' . $lang['ICQ'] . '" border="0" /></a>';
$icq = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $row['user_icq'] . '">' . $lang['ICQ'] . '</a>';
$icq_status_img = '';
$icq_img = '';
$icq = '';
$aim_img = ( $row['user_aim'] ) ? '<a href="aim:goim?screenname=' . $row['user_aim'] . '&message=Hello+Are+you+there?"><img src="' . $images['icon_aim'] . '" alt="' . $lang['AIM'] . '" title="' . $lang['AIM'] . '" border="0" /></a>' : '';
$aim = ( $row['user_aim'] ) ? '<a href="aim:goim?screenname=' . $row['user_aim'] . '&message=Hello+Are+you+there?">' . $lang['AIM'] . '</a>' : '';
$msn_img = ( $row['user_msnm'] ) ? '<a href="' . $temp_url . '"><img src="' . $images['icon_msnm'] . '" alt="' . $lang['MSNM'] . '" title="' . $lang['MSNM'] . '" border="0" /></a>' : '';
$msn = ( $row['user_msnm'] ) ? '<a href="' . $temp_url . '">' . $lang['MSNM'] . '</a>' : '';
$yim_img = ( $row['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $row['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
$yim = ( $row['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $row['user_yim'] . '&.src=pg">' . $lang['YIM'] . '</a>' : '';
$temp_url = append_sid("search.$phpEx?search_author=" . urlencode($username) . "&showresults=posts");
$search_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_search'] . '" alt="' . sprintf($lang['Search_user_posts'], $username) . '" title="' . sprintf($lang['Search_user_posts'], $username) . '" border="0" /></a>';
$search = '<a href="' . $temp_url . '">' . sprintf($lang['Search_user_posts'], $username) . '</a>';
$row_color = ( !($i % 2) ) ? $theme['td_color1'] : $theme['td_color2'];
$row_class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
$template->assign_block_vars('memberrow', array(
'ROW_NUMBER' => $i + ( $start + 1 ),
'ROW_COLOR' => '#' . $row_color,
'ROW_CLASS' => $row_class,
'USERNAME' => $username,
'FROM' => $from,
'JOINED' => $joined,
'POSTS' => $posts,
'AVATAR_IMG' => $poster_avatar,
'PROFILE_IMG' => $profile_img,
'PROFILE' => $profile,
'SEARCH_IMG' => $search_img,
'SEARCH' => $search,
'PM_IMG' => $pm_img,
'PM' => $pm,
'EMAIL_IMG' => $email_img,
'EMAIL' => $email,
'WWW_IMG' => $www_img,
'WWW' => $www,
'ICQ_STATUS_IMG' => $icq_status_img,
'ICQ_IMG' => $icq_img,
'ICQ' => $icq,
'AIM_IMG' => $aim_img,
'AIM' => $aim,
'MSN_IMG' => $msn_img,
'MSN' => $msn,
'YIM_IMG' => $yim_img,
'YIM' => $yim,
'U_VIEWPROFILE' => append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$user_id"))
$i++;
while ( $row = $db->sql_fetchrow($result) );
$db->sql_freeresult($result);
if ( $mode != 'topten' || $board_config['topics_per_page'] < 10 )
$sql = "SELECT count(*) AS total
WHERE user_id <> " . ANONYMOUS;
if ( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Error getting total users', '', __LINE__, __FILE__, $sql);
if ( $total = $db->sql_fetchrow($result) )
$total_members = $total['total'];
$pagination = generate_pagination("memberlist.$phpEx?mode=$mode&order=$sort_order", $total_members, $board_config['topics_per_page'], $start). ' ';
$pagination = ' ';
$total_members = 10;
'PAGINATION' => $pagination,
'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / $board_config['topics_per_page'] ) + 1 ), ceil( $total_members / $board_config['topics_per_page'] )),
'L_GOTO_PAGE' => $lang['Goto_page'])
$template->pparse('body');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
<form method="post" action="{S_MODE_ACTION}">
<table width="100%" cellspacing="2" cellpadding="2" border="0" align="center">
<tr>
<td align="left"><span class="nav"><a href="{U_INDEX}" class="nav">{L_INDEX}</a></span></td>
<td align="right" nowrap="nowrap"><span class="genmed">{L_SELECT_SORT_METHOD}: {S_MODE_SELECT}  {L_ORDER} {S_ORDER_SELECT}
<input type="submit" name="submit" value="{L_SUBMIT}" class="liteoption" />
</span></td>
</tr>
</table>
<table width="100%" cellpadding="3" cellspacing="1" border="0" class="forumline">
<tr>
<th height="25" class="thCornerL" nowrap="nowrap">#</th>
<th class="thTop" nowrap="nowrap"> </th>
<th class="thTop" nowrap="nowrap">{L_USERNAME}</th>
<th class="thTop" nowrap="nowrap">{L_EMAIL}</th>
<th class="thTop" nowrap="nowrap">{L_FROM}</th>
<th class="thTop" nowrap="nowrap">{L_JOINED}</th>
<th class="thTop" nowrap="nowrap">{L_POSTS}</th>
<th class="thCornerR" nowrap="nowrap">{L_WEBSITE}</th>
</tr>
<tr>
<td class="{memberrow.ROW_CLASS}" align="center"><span class="gen"> {memberrow.ROW_NUMBER} </span></td>
<td class="{memberrow.ROW_CLASS}" align="center"> {memberrow.PM_IMG} </td>
<td class="{memberrow.ROW_CLASS}" align="center"><span class="gen"><a href="{memberrow.U_VIEWPROFILE}" class="gen">{memberrow.USERNAME}</a></span></td>
<td class="{memberrow.ROW_CLASS}" align="center" valign="middle"> {memberrow.EMAIL_IMG} </td>
<td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gen">{memberrow.FROM}</span></td>
<td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gensmall">{memberrow.JOINED}</span></td>
<td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gen">{memberrow.POSTS}</span></td>
<td class="{memberrow.ROW_CLASS}" align="center"> {memberrow.WWW_IMG} </td>
</tr>
<tr>
<td class="catBottom" colspan="8" height="28"> </td>
</tr>
</table>
<table width="100%" cellspacing="2" border="0" align="center" cellpadding="2">
<tr>
<td align="right" valign="top"></td>
</tr>
</table>
<table width="100%" cellspacing="0" cellpadding="0" border="0">
<tr>
<td><span class="nav">{PAGE_NUMBER}</span></td>
<td align="right"><span class="gensmall">{S_TIMEZONE}</span><br /><span class="nav">{PAGINATION}</span></td>
</tr>
</table></form>
<table width="100%" cellspacing="2" border="0" align="center">
<tr>
<td valign="top" align="right">{JUMPBOX}</td>
</tr>
</table>
