HELP
comandor
Помогнете моля ви.Каква може да е причината да не мога да си вляза в админ панела?
Предполагам пхпбб2 ? Данеби да си забравил да кликнеп на "Влез в администраторския панел" Виж данеси объркал паролата. Виж mysql -a как е. Миля че трябва да няма проблеми. Рестартни mysql сървъра.
В краен случай преинсталл :cry: :wink:
Всичко си вървеше.5 мин оправях инфото за форума.Излязох от форума.След 5 мин не искаше да влеза в админ панела и тва е.
Ето какво изписва:
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the  Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the  Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
Знам.От тогава на сам имам нет(както се вижда щом ви пиша) и незнам от какво ще е...просто гаден е**н случай... :(
Дане би да си променил там дето се пише localhost(URL на форума) защото аз веднаж го промених и вече не можех да влизам в менюто...щом си барал кофигурацията
Сигурно да за тва ще съм най сигурен,ама как може да се оправи?Там е въпроса. :(
comandor каза:
и аз го тарсех ама не стана като помисля трябва да е базата дани да намериш таблицата за конфигурация :)
STaNiMiR каза:
comandor каза:
Я дай малко инфо.
1. Къде се хоства този форум?
на твоя компютър (т.ест localhost)
на платен хостинг (напр. host.bg)
безплатен хостинг за форуми (напр. www.myfreebb.com)
В случай, че е първото, уеб сървъра ти е изключл или забил.
Ако е платен, провери дали изобщо има връзка до сървъра (не само до твоя сайт).
Ако е третия случай не ти остава нищо друго освен да чакаш и да стискаш палци да не са прекратили услугата защото на подобни сървъри никой не ти дава право да пипаш БД-то.
Тази грешка дето си я пейстнал е дефаулт съобщението на IE, когато не може да намери даден адрес или нямаш нет.
Провери все пак адреса да не го бъркаш? Звучи банално и ламерско, но по някога се случват и такива грешки.
