MALKO HELP!!!
  • Автор Автор oxid
  • Начална дата Начална дата
oxid
:oops: Dava mi greshka v red 107
na parvia kod
ina 66 red na vtoria kod
Niakoi moje li da mi pomogne i da mi kaje kakvo trqbva da se napishe PLS
1 kod config.php
class CConfig extends CXMLParser {
* current depth in xml tree
* @var int
* @access private
var $depth = 0;
* depth tags parser helper
* @var array
* @access private
var $tags = array();
* config tree
* @var array
* @access public
var $vars = array();
* creates the xml parser and optionally loads a config file
* @param string $file_name config file name to load
* @return void
* @access public
function CConfig($file_name = "") {
parent::CXMLParser();
if ($file_name != "")
$this->Load($file_name);
* xml parser open tag handler
* @param object $parser actual expat parser
* @param string $tag current xml tag
* @param array $attr current tag attributes
* @return void
* @acces private
function HNDTagOpen($parser,$tag,$attr) {//echo "<pre>";
// call parent to save tag and attr info for cdata handler
parent::HNDTagOpen($parser,$tag,$attr);
// expand helper tag array
$this->tags[$this->depth] = $tag;
$this->depth++;
// prepare dynamic code for attr handling
foreach ($this->tags as $key => $val)
$code[] = "\"" . strtolower($val) . "\"";
// build code
$node = implode("][",$code);
$code = "foreach (\$attr as \$key => \$val) if (\$key != \"NAME\") \$this->vars[$node][strtolower(\$key)] = \"\$val\"; else \$this->vars[\$attr[\"NAME\"]][strtolower(\"\$key\")] = \"\$val\";";
// and finally execute
eval($code);
* close tag handler
* @return void
* @access private
function HNDTagClose($parser,$tag) {
// compress helper tag array
unset($this->tags[$this->depth]);
$this->depth--;
* character data handler
* @param string $cdata current tag character data
* @return void
* @access private
function HNDCData($parser,$cdata) {
$cdata = str_replace("[amp]","&",$cdata);
//echo "<br>" . $cdata;
// create the proper tree node if NAME attribute is set
if ($this->attr["NAME"] != "")
$this->tags[count($this->tags) - 1] = $this->attr["NAME"];
// cleanup cdata
$cdata = trim($cdata);
//$cdata = preg_replace("/(\015\012)|(\015)|(\012)/","",$cdata);
// only parse if cdata not void
if ($cdata != "") {
//print_r($this->attr);
// build code
$code = "\$this->vars[" . implode("][",$code) . "] = \"" . $cdata . "\";";
eval($code);
* load the config file and parse it
* @param string $file_name config filename to load
* @return void
* @acces public
function Load($file_name) {
parent::Parse($this->data = str_replace("&","[amp]",GetFileContents($file_name)));
$this->vars = ArrayReplace("[amp]" , "&" , $this->vars );
2 kod database.php
// return types
define("DB_RT_ARRAY",0); // return row as an assoc aray where fieldnames are keys
define("DB_RT_OBJECT",1); // return row as an object where fieldnames are properties
class CDatabase{
* database type
* @var string
* @access private
var $type;
* database connection id
* @var resource
* @access private
var $conn_id;
* name of the current selected database
* @var string
* @access private
var $current_db;
* number of queries per session
* @var int
* @access private
var $num_queries;
* specifies if there were any modifications to the database [write queries]
* @var bool
* @access private
var $modif = FALSE;
* initializes module and connects to the database
* @param array $connect_params connection parameters
* @return void
* @acces public
* @see Connect
function CDatabase($connect_params = "") {
$this->name = "database";
$this->type = $type;
if ($connect_params != "")
$this->Connect($connect_params);
* connects to the database
* @return void
* @access public
function Connect($connect_params = "") {
extract($connect_params);
//resource mysql_connect ( [string server [, string username [, string password [, bool new_link !!! [, int client_flags ]]]]] )
$this->conn_id = mysql_connect($server,$login,$password,TRUE) or die("CDatabase::Connect() error " . mysql_error($this->conn_id));
if ($default != "")
$this->SelectDB($default);
* closes the database connection
* @return void
* @access public
function Close() {
mysql_close($this->conn_id);
* selects and sets the current database
* @param string $database
* @return void
* @access public
function SelectDB($database) {
mysql_select_db($database,$this->conn_id) or die("CDatabase::SelectDB() error");
$this->current_db = $database;
* queries the database
* @param string $query actual sql query
* @return resource or NULL
* @access public
function Query($query,$db = "") {//debug($query);
$this->num_queries++;
//$this->SelectDB($this->current_db);
//echo "<br>$query";
if ($db)
$result = mysql_db_query($db ,$query,$this->conn_id);// or die(mysql_error());
$result = mysql_query($query,$this->conn_id) or die($query . mysql_error());
if (in_array(substr($query,0,strpos($query," ")),array("INSERT", "UPDATE", "DELETE")))
$this->modif = TRUE;
return $result;
function FetchObject($result) {
return mysql_fetch_object($result);
function FetchRow($result) {
return mysql_fetch_row($result);
function FetchArray($result,$result_type = MYSQL_ASSOC) {
return mysql_fetch_array($result,$result_type);
function NumRows($result) {
return mysql_num_rows($result);
function AffectedRows() {
return mysql_affected_rows($this->conn_id);
function InsertID() {
return mysql_insert_id($this->conn_id);
function NumQueries() {
return $this->num_queries;
function QFetchObject($query) {
return $this->FetchObject($this->Query($query));
function QFetchRow($query) {
return $this->FetchRow($this->Query($query));
function QFetchArray($query) {
return $this->FetchArray($this->Query($query));
* returns the number of rows from a table based on a certain [optional]
* where clause
* @param string $table table in which to count rows
* @param string $where_clause optional where clause [see sql WHERE clause]
* @return int row count
* @access public
function RowCount($table,$where_clause = "") {
$result = $this->FetchRow($this->Query("SELECT COUNT(*) FROM `$table` $where_clause;"));
return $result[0];
* fetch an array w/ rows from the database
* @param resource $result sql query result
* @param int $return_type row return type [can be DB_RT_ARRAY or DB_RT_OBJECT]
* @param string $key key the returned array by a certain row field [defaults to ""]
* @return array with rows or NULL if none fetched
* @access public
function FetchRowArray($result,$return_type = DB_RT_ARRAY,$key = "") {
$ret_val = array();
$i = 0;
// dont panic. its just ternary operators in action :]
while ($row = (($return_type == DB_RT_ARRAY) ? $this->FetchArray($result) : $this->FetchObject($result)))
$ret_val[(($key == "") ? $i++ : (($return_type == DB_RT_ARRAY) ? $row["$key"] : $row->$key))] = $row;
// see if any rows were fetched and return accordingly
return (count($ret_val) != 0) ? $ret_val : NULL;
* FetchRowArray wrapper
* @param string $query sql query to send to FetchRowArray
* @return array
* @access public
* @see CDatabase::FetchRowArray
function QFetchRowArray($query,$return_type = DB_RT_ARRAY,$key = "") {
return $this->FetchRowArray($this->Query($query),$return_type,$key);
* returns an array w/ the tables fields
* @param $table database table from which to get rows
* @return array
* @access public
function GetTableFields($table) {
$fields = $this->QFetchRowArray("SHOW FIELDS FROM `$table`");
$ret_val = array();
foreach ($fields as $field)
$ret_val[] = $field["Field"];
return $ret_val;
* fetches a row from a table based on a certain id using the SELECT SQL query
* @param string $table table in which to perform select
* @param int $id row id to fetch
* @param string $fields comma separated list of row fields to fetch [defaults to `*' all]
* @param int $return_type row return type DB_RT_ARRAY|DB_RT_OBJECT [defaults to DB_RT_ARRAY]
* @return array w/ the fetched data or NULL if id not found
* @access public
function QuerySelectByID($table,$id,$fields = "*",$return_type = DB_RT_ARRAY) {
// build query
$query = "SELECT $fields FROM `$table` WHERE `id` = '$id'";
// fetch row
return ($return_type == DB_RT_ARRAY) ? $this->QFetchArray($query) : $this->QFetchObject($query);
* complex fetch row array w/ WHERE/LIMIT/ORDER SQL clauses and page modifier
* @param string $table table to fetch rows from
* @param string $where_clause SQL WHERE clause [use empty to ignore]
* @param int $start limit start
* @param int $count number of rows to fetch
* @param bool $pm page modifier. if set to TRUE [default] $start becomes the page
* @param string $order_by field to order the result by [defaults to void]
* @param string $order_dir order direction. can be ASC or DESC [defaults to ASC]
* @param int $return_type row return type [DB_RT_ARRAY(default)|DB_RT_OBJECT]
* @return array w/ fetched rows or NULL
* @access public
function QuerySelectLimit($table,$fields,$where_clause,$start,$count,$pm = TRUE,$order_by = "",$order_dir = "ASC",$return_type = DB_RT_ARRAY) {
// check if $count is empty just to be safe
$count = ($count == "") ? 0 : $count;
// recompute $start if page modifier set
$_start = ($pm == TRUE) ? ((($start == 0) ? 1 : $start) * $count - $count) : $start;
// setup order clause
$order_clause = ($order_by != "") ? "ORDER BY $order_by " . (in_array($order_dir,array("ASC","DESC")) ? "$order_dir " : "") : "";
// setup where clause
$where_clause = ($where_clause != "") ? "WHERE $where_clause " : "";
// limit clause
$limit_clause = ($start >= 0) ? "LIMIT $_start,$count" : "";
// build query
$query = "SELECT $fields FROM `$table` {$where_clause}{$order_clause}{$limit_clause}";
// fetch rows
return $this->QFetchRowArray($query,$return_type);
* builds and performes a SQL INSERT query based on the user data
* @param string $table table in which to perform insert
* @param array $fields associative array w/ the row fields to be inserted
* @return void
* @access public
function QueryInsert($table,$fields) {
// first get the tables fields
$table_fields = $this->GetTableFields($table);
if (count($fields) == 0) {
$names[] = "id";
$values[] = "''";
} else
// prepare field names and values
foreach ($fields as $field => $value)
// check for valid fields
if (in_array($field,$table_fields)) {
$names[] = "`$field`";
$values[] = is_numeric($value) ? $value : "'" . addslashes($value) . "'";
// build field names and values
$names = implode(",",$names);
$values = implode(",",$values);
// perform query
$this->Query("INSERT INTO `$table` ($names) VALUES($values)");
return $this->InsertID();
* builds and performs a SQL UPDATE query based on the user data
* @param string $table table in which to perform update
* @param array $fields associative array w/ the fields to be updated
* @param string $where_clause update where clause [see SQL WHERE clause]
* @return void
* @access public
function QueryUpdate($table,$fields,$where_clause) {
if (is_array($fields)) {
// prepare query
$pairs[] = "`$field` = " . (is_numeric($value) ? $value : "'" . addslashes($value) . "'");
// $values[] = ;
// build and perform query
if (is_array($pairs))
$this->Query("UPDATE `$table` SET " . implode(", ",$pairs) . " WHERE($where_clause)");
* @return void
* @access public
function QueryUpdateByID($table,$fields) {
$id = $fields["id"];
unset($fields["id"]);
$this->QueryUpdate($table,$fields,"`id` = '$id'");
