Когато влезна във индекса ми дава:
Когато се логна:
И не ме праща към welcome.php
А и това вярно ли е:?
Свали файловете
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at C:\xampp\htdocs\secu.php:1) in C:\xampp\htdocs\index.php on line 5
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\xampp\htdocs\secu.php:1) in C:\xampp\htdocs\index.php on line 5
Когато се логна:
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\secu.php:1) in C:\xampp\htdocs\index.php on line 19
Администрация
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\secu.php:1) in C:\xampp\htdocs\index.php on line 60
Warning: Unknown: Your script possibly relies on a session side-effect which existed until PHP 4.2.3. Please be advised that the session extension does not consider global variables as a source of data, unless register_globals is enabled. You can disable this functionality and this warning by setting session.bug_compat_42 or session.bug_compat_warn to off, respectively in Unknown on line 0
Ето и файловете, че така ще Ви стане много убъркано...<?php
define('IN_VALID', true);
include("config.php");
session_start();
$user_check=mysql_real_escape_string($_SESSION['login_user']);
$ses_sql=mysql_query("select username from admin where username='$user_check' ");
$row=mysql_fetch_array($ses_sql);
$login_session=$row['username'];
if(!isset($login_session))
header("Location: index.php");
Свали файловете
